Выберете то, что вам нужно
Remove the battery.
Remove the two T5 Torx screws.
Prise off the lower casing towards the right in the picture, taking care not to break the two tabs
Carefully lift up the board from the left-hand side allowing it to 'hinge' on the metallic ribbon connector you have just noted and allow it to lay flat
The freed connector for the screen should have unfolded
Now the screen can be pried from the outer case, but take care as you do so not to tear the metallic ribbon between the two casings
To detach the screen it can help to use a pry tool to push the screen from behind through the slot
Once the connecter is pushed through the slot, you should now stick the new screen into place using suitable adhesive strip
Fold down the ribbon connector from the screen and carefully fold the two casing halves together again, making sure that the two connectors are sticking out of the side
Reinsert the ribbon connector on the left hand side and push down the retaining catch
8 участников успешно повторили данное руководство.
2 Комментариев
Nice detailing of the teardown steps but the phone shown here is a regular HTC Wildfire (HTC G8) and not the latter HTC Wildfire S (HTC G13). Apparently, the orignal Wildfire has two variants (A3333 and A310e). Each variant uses a different digitizer (the touch glass panel on top of the actual LCD). If you need to buy a replacement digitizer, verify if your variant has an IC on the digitizer ribbon cable or not. On my phone, the shattered original digitizer had no IC on the ribbon and when I replaced it with one that had one, the phone wouldn’t recognize the touch inpupts.
Nice! If you wanna recycle any mobile screen you can contact LCD's Buyers
Thanks
