Выберете то, что вам нужно
identify the exact type of your ThinkPad
get the right fan assembly, in this case FRU P/N: 42W2779
disconnect power-supply
detach battery
lift the keyboard carefully
Use a spudger to detach the cable
lift the keyboad and leave it on the side
carefully lift the wireless antenna cable from the cable guide
unscrew the last two screws from the keyboard bezel
unscrew the fist, tiny screw of the clip
unscrew the longer screw of the clip
remove the clip
remove the shorter screw of the second clip
remove the longer screw of the second clip
remove the clip
remove the last two screws of the fan assembly
detach the power cord with a spudger
CPU with thermal grease
other chip with termal grease
carfully lift the fan assembly
you may need to pull a little more because of the thermal grease
get some alcohol on the wiper
clean the CPU with the wiper
clean the chip with the wiper
Ensure there is no old thermal grease left
Follow this guide to add new thermal paste to the CPU.
now place the new fan assembly
press down the CPU- and chip-connector
don't forget to plugin the power cable of the fan assembly
6 участников успешно повторили данное руководство.
2 Комментариев
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
