Fix Your Stuff
Right to Repair
Parts & Tools
  1. identify the exact type of your ThinkPad get the right fan assembly, in this case FRU P/N: 42W2779 disconnect power-supply
    • identify the exact type of your ThinkPad
    • get the right fan assembly, in this case FRU P/N: 42W2779
    • disconnect power-supply
    • detach battery
  2. find all five screws with the shown symbols and unscrew them find all five screws with the shown symbols and unscrew them
    • find all five screws with the shown symbols and unscrew them
  3. unscrew all the shown screws These ones are tiny
    • unscrew all the shown screws
    • These ones are tiny
    • watch the sizes of the screws
  4. remove the palm rest carefully If you have a touchpad or fingerprint reader watch the cables
    • remove the palm rest carefully
    • If you have a touchpad or fingerprint reader watch the cables
    • blow the dust away
  5. lift the keyboard carefully watch the cable Use a spudger to detach the cable
    • lift the keyboard carefully
    • watch the cable
    • Use a spudger to detach the cable
    • lift the keyboad and leave it on the side
  6. just for reference: images showing the keyboard-connector blow the dust away blow the dust away
    • just for reference: images showing the keyboard-connector
  7. unscrew the left and right screw of the keyboard bezel and speakers unscrew the left and right screw of the keyboard bezel and speakers
    • unscrew the left and right screw of the keyboard bezel and speakers
  8. unscrew the first two screws of the shielding unscrew the first two screws of the shielding
    • unscrew the first two screws of the shielding
  9. carefully lift the wireless antenna cable from the cable guide unscrew the last two screws from the keyboard bezel unscrew the last two screws from the keyboard bezel
    • carefully lift the wireless antenna cable from the cable guide
    • unscrew the last two screws from the keyboard bezel
  10. watch the claws of the bezel (Sorry, no image!) carefully pull out the keyboard bezel
    • watch the claws of the bezel (Sorry, no image!)
    • carefully pull out the keyboard bezel
    • flip the bezel 180°
    • watch the cables
  11. remove the wireless antenna cable from the cable guide of the fan assembly
    • remove the wireless antenna cable from the cable guide of the fan assembly
    • you might want to use a metal spudger to widen the cable guide if necessary
  12. unscrew the fist, tiny screw of the clip unscrew the longer screw of the clip
    • unscrew the fist, tiny screw of the clip
    • unscrew the longer screw of the clip
    • remove the clip
  13. remove the shorter screw of the second clip remove the longer screw of the second clip
    • remove the shorter screw of the second clip
    • remove the longer screw of the second clip
    • remove the clip
  14. remove the last two screws of the fan assembly detach the power cord with a spudger
    • remove the last two screws of the fan assembly
    • detach the power cord with a spudger
  15. CPU with thermal grease other chip with termal grease
    • CPU with thermal grease
    • other chip with termal grease
    • carfully lift the fan assembly
    • you may need to pull a little more because of the thermal grease
  16. blow the dust away take a spudger and remove the old thermal grease
    • take a spudger and remove the old thermal grease
  17. get a paper-wiper wrap the wiper around the spudger
    • get a paper-wiper
    • wrap the wiper around the spudger
  18. get some alcohol on the wiper clean the CPU with the wiper
    • get some alcohol on the wiper
    • clean the CPU with the wiper
    • clean the chip with the wiper
    • Ensure there is no old thermal grease left
    • Follow this guide to add new thermal paste to the CPU.
  19. now place the new fan assembly pay attention to the thermal grease on the backside of your new fan assembly press down the CPU- and chip-connector
    • now place the new fan assembly
    • pay attention to the thermal grease on the backside of your new fan assembly
    • press down the CPU- and chip-connector
    • don't forget to plugin the power cable of the fan assembly
Заключение
4 участников успешно повторили данное руководство.
Dennis
Участник с: 06.01.2013
257 Репутация
1 руководство автора
Комментариев: 2
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
tech4eleven - Ответить
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
Ioannis Kolaxis - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 57
За всё время: 17,143
