Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.
Выберете то, что вам нужно
  1. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece., Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: шаг 1, изображение 1 из 1
    • Remove the foam speaker cover. Locate (4) T5 Torx screws and remove.
    Extend right earpiece/headband fully to remove cover more easily.
    Joey - Ответить
  2. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: шаг 2, изображение 1 из 1
    • Remove (3) Phillips #000 screws.
    • Remove circuit board
    Ensure you have enough torque! These were very difficult to remove with jeweler’s screwdrivers.
    Joey - Ответить
  3. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: шаг 3, изображение 1 из 2 Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: шаг 3, изображение 2 из 2
    • Optional, remove media buttons section by removing (3) Phillips #000 screws.
    • Cut a circular piece of foam and stuff it under the center section.
    • You are now finished! Just reassemble
Заключение
7 участников успешно повторили данное руководство.
SYN1ST3R
Участник с: 03/06/10
327 Репутация
1 руководство автора
6 Комментариев
Please, can you help with silencing the low battery sound?
Houssam - Ответить
OMG.. Best tutorial! I was looking at completing this and then stumbled upon your post.
The button rattle was driving me nuts!
TropiKalSTORM - Ответить
Warning: this is a huge pain! I can confirm it does work though, so thank you!
Some tips:
- After removing the 4 Torx, fully extend the adjustable arm of the right earpiece/headband, it will make it easier to remove the cover
- There are very thin delicate wires connecting the PCB to the earpiece, making everything more difficult
- I could not generate enough torque with my thin stainless jewelers screwdrivers, trying as hard as I could. I recommend a large handle screwdriver. I ended up putting my jewelers screwdriver in my drill, this worked perfectly.
- I used a cut up earplug for the foam, works well, but was hard to shove into place
- Remember to put the sliding switch back into place before putting the screws in for the PCB when putting back together
Joey - Ответить
Can anybody help me with the on/off (bluetooth/stick) switch? It’s the worst button ever. Function only after 5 or 6 tries. Ruining my nails every time. Is it replacable?
Peter Claassen - Ответить
My kitty got a hold of my Logitech H800 and chewed on the microphone - I was wondering if there is a step on how to replace the microphone on the Logitech H800?
albwillin - Ответить
Very helpful for a 'tear-down'. I have bought 4 of these S/H on eBay over the years and still like them.
I left one in a pub (they were gone when I returned the next day) and have mislaid another. I bought a third pair for my elderly father who couldn't get used to the awkward switch and indeed (due to dementure?) has worn away the tiny ridge on it. It now works using a fingernail.
My 4th pair are used daily but a couple of days ago I noticed a buzzing noise as they were charging. On picking them up, I found the micro-USB connector to be hot, so disconnected. I then realised I had just come in from wearing the headset outside in pretty bad rain, so assume there was some shorting going on around the connector? Since then, there's an intermittent connection (oxidation of contacts?), which is why I ended up here.
Have tried contact cleaner, which helps a bit, but think I need to get the soldering iron out and replace the connector.
So, thank you! :-)
renWeb - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 38
За всё время: 7,073
