Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Got a small aluminum piece from a used Mac battery A1175
Grind both upper and lower side off the piece so it fit just against the right wall off MacBook
Drilled Ø 4 mm (better measure your own piece) and glued with cyanoacrylate the very far of the small metal tab.
Get a push-button small enough to fit below the mother board (beware of a thick piece (maybe transformer)) that can avoid placing your switch. My switch come from www.conrad.fr with ref n° 705325 (perfect fit at the chosen place)
Solder two thin wire ~ 4cm very close to the switch body, routing them so they don't touch the motherboard.
Test the on/off with ohmmeter, adjust the hole eventually the alu piece move well.
Еще один человек закончил это руководство.
Прикрепленные документы
5 Комментариев
Hi, do you think the connectors on the IO board is identical of the A1369? My power button doesn't work either.
Here is a picture https://d3nevzfk7ii3be.cloudfront.net/ig...
Thanks for the guide, but that's a really bad soldering job, and the kind of wire used is totally wrong.
Bridging those jumpstart mobo pins (maybe at the ends of the power button on the plastic sleeves with a really thin copper wire) would be a way, way better done job.
Wow, this is so unnecessarily convoluted, why not just replace the keyboard?
Hello Sam, did you replace your keyboard ? If yes, did it work as well ? (Repairing MacBook Air 2011 A1370 On/Off switch.
I fink this is the right procedure to put your MacBook on the way again !
2. Just as a contribution to Apple lovers, here in Brazil Apple representatives doesn´t makes any repair in Apple products with 5 ou more years of use , because this is the legal statement here. In case of malfunction, just discard and buy another, is the Apple answer to your customeres…just like that. No comments.
Best Regards, JARI.
Yeah, I’d agree with the other posts… This could be easily repaired the correct way.
Chances are, if your power button doesn’t work, but the other keys do, it is a trackpad cable (which also powers the keyboard via the keyboard cable connected to the track pad) issue. Most likely there is corrosion on one of the ends (or all ends) of the cable/connectors.
A new $5 cable from the track pad to the logic board, along with a cleaning of 90+% rubbing alchohol on both connectors, will 95% of the time fix this issue.
I applaud for “fixing” this, but man… the poor macbook air didn’t deserve that…
