Repairing NEC VT700 Lamp Cover
Выберете то, что вам нужно
  1. Repairing NEC VT700 Lamp Cover, The Root of the Problem: шаг 1, изображение 1 из 2 Repairing NEC VT700 Lamp Cover, The Root of the Problem: шаг 1, изображение 2 из 2
    • This is the bottom of the projector with the lamp cover removed. The long rectangle shaped slot in the center of the photo has a micro switch located at the far end that would indicate the cover being in place.
    • This is the inside of the lamp cover. At the marked location (sorry the repair is already in place) there should be a plastic "L" shaped extension from the cover. This would extend into the slot in the first photo and actuate the switch indicating the cover is in place. This was broken off of the cover.
  2. Repairing NEC VT700 Lamp Cover, The Fix: шаг 2, изображение 1 из 1
    • Carefully locating the hole with the marking of the missing piece, drill a hole suitable for a screw of about 3 mm diameter. The screw needs to extend about 10 mm from the surface of the lamp cover to actuate the switch, but it should not extend much beyond this.
    • The screw goes through the cover, from the outside of the lamp cover and must extend into the slot mentioned in step 1.
    • All better! The projector now works as intended.
    FANTASTIC!!!
    We were just about to purchase a new projector. This fix was PERFECT!
    THANK YOU!!!!
    wfesner - Ответить
    Thanks s much, I put a small piece Of electrical tape around the screw so that metal didn’t touch metal. I also wondered if a plastic screw would work but it is important to not have the screw extend too far into the well. Thanks so much this is a great help.
    paulfloyd - Ответить
Заключение
5 участников успешно повторили данное руководство.
Russel Miles
Участник с: 12/17/14
124 Репутация
1 руководство автора
4 Комментариев
Thanks for the info !
I knew it was the lamp cover but It was on properly. Did not notice the missing part of plastic that activated the switch !
I little crazy glue and Kids are now happy again !
Roger Champagne - Ответить
Wonderful solution, you just saved us potentially $25 for a new cover ($5 part from NEC, plus $15 minimum, plus $10 shipping) or a $2,000 for a new projector since they don't carry parts for it anymore (except the overpriced cover). Thank you!!
Full Doc Brown - Ответить
Thanks so much for the tip. I did this on mine and it works like a charm!
djjamiec - Ответить
FANTASTIC!!!
THANK YOU!!!!
wfesner - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 13
За всё время: 5,436
