Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Sometimes the motor stops, heating still is in function. You can fix this in 15 min.
Запчасти
Детали не указаны.
  1. Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
    • Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
  2. Open the bottom with a strong screwdriver. Be careful not to break the clips inside Open the bottom with a strong screwdriver. Be careful not to break the clips inside
    • Open the bottom with a strong screwdriver. Be careful not to break the clips inside
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
    • Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
  5. Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug. If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable. If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
    • Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug.
    • If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable.
    • If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
  6. Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic threee times. At last switch must be pressed in.
    • Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic threee times. At last switch must be pressed in.
Заключение
To proof the function use water.
20 участников успешно повторили данное руководство.
VauWeh
Участник с: 19.10.2015
101 458 Репутация
Автор 125 руководств
Комментариев: 31
Bravo, vielen Dank. Hat bestens funktioniert, in 5 min war alles erledigt!
jschiedermair - Ответить
Many thanks!
I couldn't believe reversing polarity would work, but it did!
J.
jeroenvaneijk - Ответить
Yes, it's a miracle. :-)
VauWeh -
If reversing the wires solves your problem then it was just a loose or poor contact at the switch causing the problem.
You are not switching polarity when swapping the wires. Like a light switch, it only serves as a connection/disconnection point for electrical flow.
ekao -
Gibt's da auch eine technische Begründung dazu, warum der bloße Tausch der Motoranschlüsse den Fehler behebt?
Ich würd's nur gerne verstehen.
Georg Sunkler - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 30
За последние 7 дней: 285
За последние 30 дней: 1,145
За всё время: 45,109
