Введение
Needed remedies:
- Screwdrivers
- Brush
- Oil
Выберете то, что вам нужно
Remove battery
Turn Netbook upside down
Unscrew all screws from the back of the pc
Remove the back plate
Unscrew metal cover on top of fan
Gently lift the fan making sure not to drop dust into the motor of the fan below
Clean fan blades
Clean the fan house
place the fan upside down so the metal pin points upwards
Apply oil
Apply one or two droplets of oil onto the metal pin
Place it on the motor and make sure it rotates without problems
In case there is still sounds coming from the fan when turned on, redo the cleaning and lubrication.
9 участников успешно повторили данное руководство.
