Выберете то, что вам нужно
Take a bus ticket or anything else that has a thickness of 0.5-0.6 mm.
Cut the ticket to form a triangle.
Insert the triangle in the gap between the button and the chassis.
Cut the part of the ticket that is out of the chassis.
Now with a paper clip tests if it works.
If it works remount the back cover. If i doesn't work probably the problem is the button and not the contact and you need to replace it.
6 участников успешно повторили данное руководство.
