Введение
Does your child have a LeapFrog Hug & Learn Baby Tad with non-functional buttons? Learn to fix it yourself with this easy guide.
This guide requires soldering. For your own safety, use lead-free solder and work in a well-ventilated area. Wear safety goggles and try to work with your head at a distance from the solder. Make sure to wash your hands after finishing your work. Do not eat or drink while working with solder.
Выберете то, что вам нужно
Open the LeapFrog's back.
Carefully pull out the battery compartment just enough to hold it in your hand.
With your Philips head screwdriver, unscrew the battery compartment and take the batteries out.
Carefully cut the cable tie with your scissors and pull it out.
The battery compartment will become loose; set it aside carefully.
Once you have the battery compartment on the side, take all the stuffing out.
Carefully cut the cloth covering the button compartment around the edges.
Remove the button compartment and set it aside.
Find all the broken or disconnected cables.
Using cable pliers or another method, strip the loose ends of the cables.
Once all the cables have been stripped, twist the ends to make them more compact.
On the button compartment, pinch the glue on both sides of the circuit board and remove it.
Put the soldering iron to warm up.
When the soldering iron is ready, place its tip on the first soldered bit that doesn't have a wire connected to it.
Once the solder begins melting, add a little pressure and you will be able to find a hole through the board.
Insert your needle through the holes you just opened and wiggle it to clear them of any extra solder.
Once you have opened all the holes needed, take a look at the board and try to figure out where each loose wire goes.
Place each end of the loose wires through the holes you made in Step 7.
Each button has a group of four wires, and the circuit board is labeled with each of the buttons' names(i.e. circle, square, diamond, etc.). You can also follow the wires that are still connected as guidance.
After you have soldered all the groups of wires, cut the excess wires on the other side of the board.
To prevent the wires from touching, use your needle to bend the wires in an up-and-down pattern throughout the board. Cover any exposed wires with electrical tape.
Once you have cut the excess wires, replace the button compartment inside the cloth bag.
Once you have put the button compartment inside, sew the hole closed using your needle and thread.
After you have sewed the button compartment back into place, you can proceed to replacing the stuffing.
Put the button compartment back inside its sleeve and secure it with the 15-inch cable tie. Cut off the excess cable tie with your scissors.
Put the battery compartment back inside, and close its back.
Enjoy your good-as-new LeapFrog Hug and Learn Baby Tad!
Once you have put all the parts back together, you should make sure all buttons are working.
Еще один человек закончил это руководство.
