Repairing Puppet Strings
Выберете то, что вам нужно
  1. Repairing Puppet Strings, Repairing Puppet Strings: шаг 1, изображение 1 из 1
    • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
  2. Repairing Puppet Strings: шаг 2, изображение 1 из 1
    • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
    • Note: Tying the knot can be tedious, so it may take a few tries.
  3. Repairing Puppet Strings: шаг 3, изображение 1 из 1
    • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
    • Note: The material may resist the needle at first.
  4. Repairing Puppet Strings: шаг 4, изображение 1 из 2 Repairing Puppet Strings: шаг 4, изображение 2 из 2
    • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
    • Note: You may want to tie a few simple knots for extra security.
  5. Repairing Puppet Strings: шаг 5, изображение 1 из 1
    • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
  6. Repairing Puppet Strings: шаг 6, изображение 1 из 1
    • Secure the two sticks with tape or glue where the two sticks cross.
    • Note: Tape is a faster fix, but may appear messier.
  7. Repairing Puppet Strings: шаг 7, изображение 1 из 1
    • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
    • Note: Repeat the previous steps to other parts of the puppet if necessary.
  8. Repairing Puppet Strings: шаг 8, изображение 1 из 1
    • This is what your puppet should look like.
    • Happy puppet-ing!
Заключение
2 участников успешно повторили данное руководство.
Stephanie Gummelt
Участник с: 10/27/15
155 Репутация
1 руководство автора
Команда
Missouri Western, Team 1-4, Adkins Fall 2015 Участник Missouri Western, Team 1-4, Adkins Fall 2015
MWSU-ADKINS-F15S1G4
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 31
За всё время: 2,983
