Введение
This repair guide is intended to prevent rattling noise from the sensor in a Logitech G303 computer mouse. There are two different adhesive methods that are described on Steps 6 and 7.
Инструменты
Запчасти
Pry off the mouse feet located at the front and back of the underside of the mouse by wedging a flat head screw driver into the depressed groove and applying upward force.
Using a Phillips #00 screwdriver, unscrew the three screws that hold the top and bottom halves of the mouse together.
Grip the mouse cable with one had and the top buttons with the other and apply force in opposite directions to separate the two halves of the mouse.
Remove the internal operating board by lifting it out of the bottom half of the mouse.
First Adhesive Method:
Apply a thin bead of the Silicon caulk to the rim of the sensor component.
Second Adhesive Method:
Attach the double sided tape to the bottom half of the housing. Place them directly over the central grooves.
To reassemble your device, follow these instructions in reverse order. Lastly, ensure that none of the adhesive is blocking the sensor on the bottom of the device.
Еще один человек закончил это руководство.
