Выберете то, что вам нужно
Do your printed papers have these or similar vertical black and yellow lines?
Then this is the tutorial for you to make them disappear
Open the printer front and take everything out
Take out the toners
Take out the drum together with the waste bin
Your printer should now look like in the image attached
Use a flashlight to see inside the printer
On the glossy black plastic you will see vertical lines of color which are the cause of your printers problem
Use a small white paper and try to stick it into the top - like shown
Move it from left to right and drag it out again
You will see that it is pretty dirty afterwards
Do this multiple times and clean the black glossy plastic with a cotton cloth - be careful not to scratch it
Close the printer again and print some pages
After the 2nd or 3rd the black vertical lines should be gone completely
Have fun - again!
12 участников успешно повторили данное руководство.
7 Комментариев
Michael I have a thick horizontal line that repeats as a Ghost image. Will this help fix it? I have tried cleaning the paper track and the rollers etc, with no such luck.
same here, if i print a blank page it has various horizontal shadows and looks dirty
My printer was many years practically only B&W because of awful colors. This trick helped to restore colors. Thank you!
Step 4: you can also clean the bottom (and not only the top) of the black glossy plastic: it was the root cause of my black lines
Tested with CLX-3185FW
Thanks
this will laso work for the samsunc clp-310(n,w) and the clp-315(n,w)
I have the same issue but with colored lines. Will this fix that too?
https://i.imgur.com/Dyqgr2n.jpg
What's the process for cleaning colored lines?
