Введение
How to disassemble the laptop in case to clean the cooling / fan system.
Выберете то, что вам нужно
Видео обзор
Switch-off the laptop and remove the battery.
To remove the Keyboard you must open 7x locking clips.
You can use a cutter and a plastic tool.
Disconnect the CPU fan cable connector.
Now you have 4x screws on the CPU side and 2x on the fan.
Separate the fan from the radiator.
Clean the radiator and the fan. Use a soft brush.
Put thermal compose to the main CPU and you are ready for assembling.
After the start-up, check if the fan works.
15 участников успешно повторили данное руководство.
8 Комментариев
Very good, thank you. :-)
I' thank you too. :)
ZFix -
Can't you just leave fan assembly installed and start cleaning it with brush and compressed air once you have bottom case cover off? What about just blowing air thru the grill covering the fan and not even removing the bottom case cover?
I just red it and found it's not for me. But i still felt I'd instantly send $1 to the author, besides those points, which i do not care of.
So I suggest to FIXIT.COM to offer it optionally. I meean... Optinally if you want you may send $1 or more to the author.... and I would put "1" ass default. I want it tobe JUST ONE CLICK. Otherwise I leave.
Merci, j'ai réussi à ouvrir mon Toshiba grâce à ce tuto. J'ai dû changer le ventilateur qui était bruillant. http://ventilaptop.com/toshiba/580002-ve...
Amazing, I’ve been wanting to open my laptop for months now this helped so much. Thank you
