Введение
This guide required
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
Remove the single 7.5mm screw with a Phillips #0 screwdriver.
Lift up the black plastic piece.
Lift the button board up and away to clear room for lifting the motherboard.
Tilt the assembly up but being wary that it is still attached to the front panel.
To reassemble, align the two black lines together by moving the belt back and forth.
Once aligned reinsert the toothed slider at the exact point shown.
be careful at the top blue button (on/off) that might come off when you align the belt
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Еще один человек закончил это руководство.
Один комментарий
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
