Введение
A Sharpie can quickly dry out if you leave the cap off too long or use it often, making it weaker or completely unusable. Many Sharpies are thrown away because of this.
If your Sharpie has become dried-out and hard to use, you can use this guide to revive its ink and keep it out of the trash.
For this guide, it is recommended that you wear gloves so that you do not get ink or rubbing alcohol on yourself.
Выберете то, что вам нужно
Use a pair of pliers to separate the black part from the grey part of the Sharpie.
Drip the rubbing alcohol into the part of the ink pad that has a sponge with a hole in its center. Do this until the sponge seems saturated (or about 5 drops).
Еще один человек закончил это руководство.
