Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Identify the screw keeping the handle in place.
Use a standard Phillips screwdriver to remove the screw(s).
Remove the handle and the metal bar to expose the base of the pan handle.
Determine what kind of cleaning is required. I used a Lysol solution, which can be substituted with soap and water.
Apply your cleaning solution to the base.
If necessary, apply cleaning solution to the handle and metal bar, as well.
Wipe the area until it is clean, repeat if necessary.
Identify the warp on the pan, if any.
Set the pan on top of a flat cloth.
Cover the warp with a second cloth. We used a different dish towel.
Align the handle onto the metal bar.
Push the handle into the metal bar socket.
Put the screw back in the socket.
Use the screw driver to tighten the screw.
5 участников успешно повторили данное руководство.
