Введение
Is your Zippo lighter not working because the flint wheel is stuck? Don't want to invest money in a brand new lighter? Your flint wheel is stuck because the steel rod it strikes is stuck at an awkward position against the wheel causing the wheel to be immobile. Find out how to loosen the steel rod and fix your Zippo!
Выберете то, что вам нужно
Open your Zippo lighter and take the inside component out of the shell simply by pulling it out.
Flip the lighter to face the bottom of the unit and locate the brass colored screw.
Loosen the brass screw with the flat head screwdriver
Unscrew the rest of the brass screw using your hand.
Unscrew the brass screw until it comes off and the spring beneath shows but do not take the spring all the way out.
Pull the brass screw and spring out about a centimeter or two to unhinge the steel rod located beneath the flint wheel so that the rod and the wheel are not touching.
Follow the steps backwards to reassemble the unit and check to see if the flint wheel is unstuck.
You have now fixed your flint wheel! Enjoy your Zippo Lighter!
32 участников успешно повторили данное руководство.
29 Комментариев
This made the problem even worse. The flint wheel is now unstuck but it can't make any sparks whatsoever.
me too it will not work i did the same and now it wont make sparks
cool kid -
Did you change the flint aswell? Change the flint and put it back together, if it won’t turn after changing the flint then loosen the spring again.
You need to replace the flint itself in that case.
Wonderful instructions! AND IT WORKED! Thank you.
