Введение
The cable of the cyclometer mount can be ripped off quiet easily right before it disappears in the case. This guide explains how to fix a ripped of cable.
Выберете то, что вам нужно
Use your cutter knife to pry open the small cap that hides the inner contacts.
Take the remaining cable and remove some of the thick black insulation as well as some of the thin insulation as shown in the picture.
Remove the broken cable by ripping it off carefully or using a soldering iron.
Use the paper clip to hold the cable at the right position.
Solder the prepared cable to the contacts.
Apply some glue to the mount and re-attach the cap to the mount.
Now go and attach the cyclometer to your bike and check that it works again.
4 участников успешно повторили данное руководство.
