Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount
Выберете то, что вам нужно
  1. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Remove the cap from the mount: шаг 1, изображение 1 из 3 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Remove the cap from the mount: шаг 1, изображение 2 из 3 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Remove the cap from the mount: шаг 1, изображение 3 из 3
    • Use your cutter knife to pry open the small cap that hides the inner contacts.
    • You probably have to go a bit deeper into the plastic as the cap is glued to the casing.
  2. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Prepare the cable: шаг 2, изображение 1 из 3 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Prepare the cable: шаг 2, изображение 2 из 3 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Prepare the cable: шаг 2, изображение 3 из 3
    • Take the remaining cable and remove some of the thick black insulation as well as some of the thin insulation as shown in the picture.
    • Remove the broken cable by ripping it off carefully or using a soldering iron.
  3. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Solder the cable to the contacts: шаг 3, изображение 1 из 2 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Solder the cable to the contacts: шаг 3, изображение 2 из 2
    • Use the paper clip to hold the cable at the right position.
    • Solder the prepared cable to the contacts.
    • Remember: the red cable left, the black cable right.
    • The contacts take up heat of the soldering iron really fast. This can lead to the contacts melting the surrounding plastic. Hence, you have to be fast.
  4. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Glue the cap to the mount: шаг 4, изображение 1 из 1
    • Apply some glue to the mount and re-attach the cap to the mount.
Заключение
Now go and attach the cyclometer to your bike and check that it works again.
4 участников успешно повторили данное руководство.
Baschtl
Участник с: 12/02/12
1 576 Репутация
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 22
За последние 30 дней: 35
За всё время: 1,110
