Repairing and Reinforcing a Closet Rack
Выберете то, что вам нужно
  1. Repairing and Reinforcing a Closet Rack, Brackets Braces C-Clamps: шаг 1, изображение 1 из 1
    • Use the putty knife and spread the dry wall compound filling any holes and damage made to the wall.
  2. Repairing and Reinforcing a Closet Rack: шаг 2, изображение 1 из 1
    • Allow the compound to dry off so as to reach maximum hardness.
  3. Repairing and Reinforcing a Closet Rack: шаг 3, изображение 1 из 1
    • Use the 100 grit sandpaper and gently sand down the areas that were puttied, thus making them flush with the wall.
    • Use safety glasses and a dust mask protecting both your lungs and eyes from any particles coming off the wall.
  4. Repairing and Reinforcing a Closet Rack: шаг 4, изображение 1 из 1
    • Measure and mark where the new holes will go for the brackets, c-clamps, and braces.
    • Allow 11"-12" of space between the side wall and the first bracket and each subsequent bracket.
    • Mark holes for the c-clamps half the distance between the brackets.
    • Use a level to guarantee the rack will be straight.
  5. Repairing and Reinforcing a Closet Rack: шаг 5, изображение 1 из 1
    • Use a drill with a 1/4" drill bit and make holes at each mark.
    • Use safety glasses when operating the drill, and be cautious and careful when handling the drill. Careless handling of the drill can lead to injury. For more information on how to properly handle a drill refer to this guide's introduction.
  6. Repairing and Reinforcing a Closet Rack: шаг 6, изображение 1 из 1
    • Use a hammer and knock the plastic anchors into the wall where the holes were drilled.
    • Use #8 plastic anchors for best results.
  7. Repairing and Reinforcing a Closet Rack: шаг 7, изображение 1 из 1
    • Use a brush and matching wall paint to coat the areas that were puttied and allow it to dry.
  8. Repairing and Reinforcing a Closet Rack: шаг 8, изображение 1 из 1
    • Use a flathead screwdriver and screw the brackets into the plastic anchors.
    • Use 1-1/4" flathead screws for best results.
  9. Repairing and Reinforcing a Closet Rack: шаг 9, изображение 1 из 1
    • Take the closet rack and place it onto the brackets.
  10. Repairing and Reinforcing a Closet Rack: шаг 10, изображение 1 из 1
    • Use a Phillips screw driver to screw the c-clamps into the plastic anchors and reinforce the rack.
    • Use Phillips #8 1-1/4" screws for best results.
  11. Repairing and Reinforcing a Closet Rack: шаг 11, изображение 1 из 1
    • Place the support braces on the rack.
    • Use a Phillips screw driver to screw them into the plastic anchors.
Финишная черта
2 участников успешно повторили данное руководство.
Bojan Krtinic
Участник с: 05/12/20
247 Репутация
1 руководство автора
Команда
York University, Team S1-G16, O'Regan Summer 2020 Участник York University, Team S1-G16, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G16
1 член
Автор 2 руководств
Один комментарий
Just a question what if you wanted to install a heavier more solid longer rod?
Chris M - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 77
За последние 30 дней: 381
За всё время: 7,593
