Repairing and Reinforcing a Closet Rack
Выберете то, что вам нужно
    1. Repairing and Reinforcing a Closet Rack, Brackets Braces C-Clamps: шаг 1, изображение 1 из 1
      • Use the putty knife and spread the dry wall compound filling any holes and damage made to the wall.
      Спросите у FixBot
      Добавить комментарий
    2. Repairing and Reinforcing a Closet Rack: шаг 2, изображение 1 из 1
      • Allow the compound to dry off so as to reach maximum hardness.
      Спросите у FixBot
    3. Repairing and Reinforcing a Closet Rack: шаг 3, изображение 1 из 1
      • Use the 100 grit sandpaper and gently sand down the areas that were puttied, thus making them flush with the wall.
      • Use safety glasses and a dust mask protecting both your lungs and eyes from any particles coming off the wall.
      Спросите у FixBot
    4. Repairing and Reinforcing a Closet Rack: шаг 4, изображение 1 из 1
      • Measure and mark where the new holes will go for the brackets, c-clamps, and braces.
      • Allow 11"-12" of space between the side wall and the first bracket and each subsequent bracket.
      • Mark holes for the c-clamps half the distance between the brackets.
      • Use a level to guarantee the rack will be straight.
      Спросите у FixBot
    5. Repairing and Reinforcing a Closet Rack: шаг 5, изображение 1 из 1
      • Use a drill with a 1/4" drill bit and make holes at each mark.
      • Use safety glasses when operating the drill, and be cautious and careful when handling the drill. Careless handling of the drill can lead to injury. For more information on how to properly handle a drill refer to this guide's introduction.
      Спросите у FixBot
    6. Repairing and Reinforcing a Closet Rack: шаг 6, изображение 1 из 1
      • Use a hammer and knock the plastic anchors into the wall where the holes were drilled.
      • Use #8 plastic anchors for best results.
      Спросите у FixBot
    7. Repairing and Reinforcing a Closet Rack: шаг 7, изображение 1 из 1
      • Use a brush and matching wall paint to coat the areas that were puttied and allow it to dry.
      Спросите у FixBot
    8. Repairing and Reinforcing a Closet Rack: шаг 8, изображение 1 из 1
      • Use a flathead screwdriver and screw the brackets into the plastic anchors.
      • Use 1-1/4" flathead screws for best results.
      Спросите у FixBot
    9. Repairing and Reinforcing a Closet Rack: шаг 9, изображение 1 из 1
      • Take the closet rack and place it onto the brackets.
      Спросите у FixBot
    10. Repairing and Reinforcing a Closet Rack: шаг 10, изображение 1 из 1
      • Use a Phillips screw driver to screw the c-clamps into the plastic anchors and reinforce the rack.
      • Use Phillips #8 1-1/4" screws for best results.
      Спросите у FixBot
    11. Repairing and Reinforcing a Closet Rack: шаг 11, изображение 1 из 1
      • Place the support braces on the rack.
      • Use a Phillips screw driver to screw them into the plastic anchors.
      Спросите у FixBot
Финишная прямая
2 человек успешно провели ремонт по этому руководству.
Bojan Krtinic
Участник с: 05/12/20
247 Репутация
1 руководство автора
Команда
York University, Team S1-G16, O'Regan Summer 2020 Участник York University, Team S1-G16, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G16
1 член
Автор 2 руководств
1 Комментарий к руководству
Just a question what if you wanted to install a heavier more solid longer rod?
Chris M - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 37
За последние 30 дней: 157
За всё время: 12,919
