Seville Classics MSC10166 Buttons Replacement
Выберете то, что вам нужно
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): шаг 1, изображение 1 из 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
    Hi I had the same problem where the fan would turn on it just wouldn't rotate. So I read all these solutions and right before I started to take the fan apart,my husband toke it and sprayed some WD-40,along the base above the plug where it rotates. Spray all around. Wait about 3mins,plug it in, and BAM it works great…. Thank God for husband's,
    tiffany Gallardo - Ответить
  2. Seville Classics MSC10166 Buttons Replacement: шаг 2, изображение 1 из 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Buttons Replacement: шаг 3, изображение 1 из 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Buttons Replacement: шаг 4, изображение 1 из 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Buttons Replacement: шаг 5, изображение 1 из 2 Seville Classics MSC10166 Buttons Replacement: шаг 5, изображение 2 из 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: шаг 6, изображение 1 из 1
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
  7. Seville Classics MSC10166 Buttons Replacement: шаг 7, изображение 1 из 1
    • Remove the buttons from the top cover.
  8. Seville Classics MSC10166 Buttons Replacement: шаг 8, изображение 1 из 1
    • Wipe down any dirt on the buttons.
  9. Seville Classics MSC10166 Buttons Replacement: шаг 9, изображение 1 из 1
    • Wipe down the frame that holds the buttons.
Заключение
2 участников успешно повторили данное руководство.
Queena Phung
Участник с: 09/26/12
114 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 15-46, Forte Fall 2012 Участник Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 членов
Автор 6 руководств
2 Комментариев
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Ответить
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 3,917
