Repairing the Loose Hands on a Fossil Women's Metallic Scarlette Es4314 Watch
Выберете то, что вам нужно
  1. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch, Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 1, изображение 1 из 2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch, Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 1, изображение 2 из 2
    • Disconnect wrist band by using the right size Push Pin for your watch to push the Spring Shaft back through the watch band hole.
    • Simultaneously push the Spring Shaft down and gently pull the band and shaft away, releasing the band.
    • By disconnecting the wrist band you will be able to open and work on the back of the watch with ease.
  2. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 2, изображение 1 из 2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 2, изображение 2 из 2
    • Place watch face down in the watch holder.
    • Tighten the holder with the wing nut on the side of the watch holder until watch is snug.
    • Righty tighty, lefty loosey
  3. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 3, изображение 1 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 3, изображение 2 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 3, изображение 3 из 3
    • Identify the correct size tooth that matches the indention on your watch's back case.
    • Screw the three identical teeth into the back case screw driver and use the wheel on the top of the screw driver to line the teeth up with the intentions on the back case.
    • Line up the teeth to the small indentions on the back of the watch, apply a slight amount of pressure, and unscrew the back case of the watch.
    • Some watches may need to be opened with a small Pry Tool, however for this particular watch you will need to utilize the watch screwdriver.
  4. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 4, изображение 1 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 4, изображение 2 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 4, изображение 3 из 3
    • Once the back of the watch is removed, use tweezers to carefully remove the first two plates which are connected.
  5. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 5, изображение 1 из 2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 5, изображение 2 из 2
    • Once the gears are exposed, inspect gears for any disconnection. If no issues are discovered, investigate other connecting parts.
    • Locate the small metal connector arm that is touching the gears and turning the minute and second hands. If it is not connecting, remove it and adjust it as needed.
    • Note: This was a very small metal arm at the bottom of the picture
  6. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 6, изображение 1 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 6, изображение 2 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 6, изображение 3 из 3
    • Remove any components you need to in order to allow you access to the connector piece.
    • Stay organized in this process as the pieces are very small and layered in a complex order. I also recommend getting a magnifying glass as some of the pieces are very small.
  7. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 7, изображение 1 из 2 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 7, изображение 2 из 2
    • Use the small mallet and tweezers from your kit to straighten and adjust your connector piece so that it makes direct contacts with the gears.
  8. Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 8, изображение 1 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 8, изображение 2 из 3 Repairing the Loose Hands on a Fossil Women's Metallic Scarlette  Es4314  Watch: шаг 8, изображение 3 из 3
    • After straightening the bent connector, reassemble your watch by starting at Step 6 and working backwards to Step 1.
Заключение
To reassemble your device, follow these instructions in reverse order starting at Step 6 and working backward to Step 1. It is imperative to replace all pieces back in the correct order. Take your time and don’t forget to breathe!
Еще один человек закончил это руководство.
Amanda Catarzi
Участник с: 02/01/20
187 Репутация
1 руководство автора
Команда
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Участник USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 членов
Автор 27 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 32
За всё время: 1,914
