How to remove scratches from an Airpods Case
Выберете то, что вам нужно
  1. How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: шаг 1, изображение 1 из 2 How to remove scratches from an Airpods Case, How to remove scratches from an Airpods Case: шаг 1, изображение 2 из 2
    • The front and back are already scarred.
  2. How to remove scratches from an Airpods Case: шаг 2, изображение 1 из 1
    • Use 2000 grit and above fine-grained sandpaper.
    • For this tutorial, I used 2500 grit directly and then 3000 grit for a finer finish.
    • Careful when choosing a grit, a too coarse sandpaper grit will damage the airpods case
  3. How to remove scratches from an Airpods Case: шаг 3, изображение 1 из 1
    • Cotton wool and medical alcohol are used to clean the surface of the charging case.
  4. How to remove scratches from an Airpods Case: шаг 4, изображение 1 из 2 How to remove scratches from an Airpods Case: шаг 4, изображение 2 из 2
    • Clean the surface of the charging case with absorbent cotton dipped in alcohol.
    • Clean up the inside too!
  5. How to remove scratches from an Airpods Case: шаг 5, изображение 1 из 1
    • Wet the surface with absorbent cotton or a little water, and then lightly sand it with 2500-grit fine sandpaper.
    • It can be seen that the more serious scratches have been smoothed out, the polished areas have turned white, and the smooth surface has become matte.
    • This step can be performed as many times as necessary.
  6. How to remove scratches from an Airpods Case: шаг 6, изображение 1 из 1
    • It has now returned to white, but the surface is still matte.
    • If you like this matte style, you can stop
    • To restore a smooth surface, continue sanding with 3000 grit sandpaper in the same way as in the previous step.
    • The finer the sandpaper, the smoother it will be.
  7. How to remove scratches from an Airpods Case: шаг 7, изображение 1 из 1
    • Refreshed now!
Заключение
This will give the charging case a refreshed look instead of a dirty, scratched surface.
27 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
zh en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Z.Heng
Участник с: 04/08/17
3 610 Репутация
Автор 3 руководств
8 Комментариев
Extremely convincing, especially the last picture.
Ludger - Ответить
感谢作者!我的AirPods也布满了划痕!
Zhang Boyang - Ответить
Kann man auch Polierpaste nutzen wie sie für Kunststoffdisplays benutzt wird?
neo1983-jahn - Ответить
How big can the scratches be ?
Albert zweisteim - Ответить
How do you get it shiny again?
lucas cheraki - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 31
За последние 7 дней: 242
За последние 30 дней: 1,020
За всё время: 75,454
