Введение
First remove the old battery and read the type and then order the new battery. The repair manual is also suitable for the Windows version Lenovo Yoga 2 851F.
Запчасти
Детали не указаны.
  1. To remove the cover and the headphone jack, follow the instructions of this guide. To remove the cover and the headphone jack, follow the instructions of this guide. To remove the cover and the headphone jack, follow the instructions of this guide.
    • To remove the cover and the headphone jack, follow the instructions of this guide.
  2. Disconnect the battery  ribbon cable. Using a flat object, squeeze the battery bracket on the side of the headphone jack out of the bracket. It should be a robust flat object as some force is needed to get the battery out. Using too much force can damage the case. Carefully pull out the battery ribbon cable  together with the battery.
    • Disconnect the battery ribbon cable.
    • Using a flat object, squeeze the battery bracket on the side of the headphone jack out of the bracket. It should be a robust flat object as some force is needed to get the battery out. Using too much force can damage the case.
    • Carefully pull out the battery ribbon cable together with the battery.
  3. Remove the screw cover on the ribbon cable side (the cover is stuck). Remove the screw and cover. The cover is wedged in on one side and therefore you need some patience to get the cover out. The old battery can then  be replaced. Pay attention to the type designation of the old and new battery when replacing it.
    • Remove the screw cover on the ribbon cable side (the cover is stuck).
    • Remove the screw and cover. The cover is wedged in on one side and therefore you need some patience to get the cover out.
    • The old battery can then be replaced. Pay attention to the type designation of the old and new battery when replacing it.
Заключение
Repeat the steps in order to reassemble your device.
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
de en
72%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Raphael Hinterndorfer
Участник с: 11.02.2019
124 Репутация
1 руководство автора
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 27
За последние 30 дней: 88
За всё время: 1,198
