Replace Siemens EQ 5 ceramic valve
Выберете то, что вам нужно
  1. Replace Siemens EQ 5 ceramic valve, Remove Siemens EQ Series side panel (tank side).: шаг 1, изображение 1 из 1
    • Never forget: pull out the mains plug!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Remove the coffee container lid and take out all the coffee beans.
  2. Replace Siemens EQ 5 ceramic valve: шаг 2, изображение 1 из 1
    • Unscrew the two Torx T10 screws at the top of the right side panel.
    • Some models do not have these screws. Then the side parts are only held by catches, some of which clamp very strongly. You may have to detach the back part first.
  3. Replace Siemens EQ 5 ceramic valve: шаг 3, изображение 1 из 3 Replace Siemens EQ 5 ceramic valve: шаг 3, изображение 2 из 3 Replace Siemens EQ 5 ceramic valve: шаг 3, изображение 3 из 3
    • Lay the machine on its side with the water tank side facing up.
    • The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
    • If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
    • Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
  4. Replace Siemens EQ 5 ceramic valve: шаг 4, изображение 1 из 1
    • You may need to pry the front edge with a plastic tool.
    • Lift the side panel off, but don't remove it completely yet. It is still connected with a silicone tube.
    • The water tank lid is located at the top of the side panel. Lift it up off the hinges.
  5. Replace Siemens EQ 5 ceramic valve: шаг 5, изображение 1 из 1
    • Pull off the silicone hose that leads to the water connection of the tank from the inside.
  6. Replace Siemens EQ 5 ceramic valve: шаг 6, изображение 1 из 2 Replace Siemens EQ 5 ceramic valve: шаг 6, изображение 2 из 2
    • Remove the cover over the electronics.
    • The second picture shows the most important components:
    • heater
    • Ceramic valve/Brew valve (depending on model)
    • electronics
    • pump
    • mute
    • flow meter
  7. Replace Siemens EQ 5 ceramic valve, EQ 5 ceramic valve: шаг 7, изображение 1 из 3 Replace Siemens EQ 5 ceramic valve, EQ 5 ceramic valve: шаг 7, изображение 2 из 3 Replace Siemens EQ 5 ceramic valve, EQ 5 ceramic valve: шаг 7, изображение 3 из 3
    • If you haven't already done so: Remove the two plastic covers over the cables and the electronics box.
  8. Replace Siemens EQ 5 ceramic valve: шаг 8, изображение 1 из 3 Replace Siemens EQ 5 ceramic valve: шаг 8, изображение 2 из 3 Replace Siemens EQ 5 ceramic valve: шаг 8, изображение 3 из 3
    • Locate the two strands of wire going from the ceramic valve to the motherboard. Unplug the connectors and unthread the cables.
  9. Replace Siemens EQ 5 ceramic valve: шаг 9, изображение 1 из 1
    • Turn the machine over. Remove the three Torx T15 screws securing the ceramic valve. Pay attention to the washers.
  10. Replace Siemens EQ 5 ceramic valve: шаг 10, изображение 1 из 1
    • Turn the machine over again.
    • Pull out the clamp on the pressure hose to the ceramic valve.
    • Pull off the pressure hose and push it aside.
  11. Replace Siemens EQ 5 ceramic valve: шаг 11, изображение 1 из 2 Replace Siemens EQ 5 ceramic valve: шаг 11, изображение 2 из 2
    • Carefully pull out the valve.
    • Pull off the thick and thin silicone hoses.
  12. Replace Siemens EQ 5 ceramic valve: шаг 12, изображение 1 из 2 Replace Siemens EQ 5 ceramic valve: шаг 12, изображение 2 из 2
    • Pull off the clamps on the other two pressure hoses. Make a note of which hose goes where and detach the two hoses.
  13. Replace Siemens EQ 5 ceramic valve: шаг 13, изображение 1 из 1
    • Remove the ceramic valve.
Заключение
Follow the steps in reverse order to reassemble your device.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
VauWeh
Участник с: 10/19/15
203 582 Репутация
Автор 246 руководств
Команда
Repair is War on Entropy Участник Repair is War on Entropy
Community
25 членов
Автор 1 121 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 21
За последние 30 дней: 108
За всё время: 6,679
