Выберете то, что вам нужно
Open the battery compartment, check bObsweep Robotic Vacuum Battery Replacement
Extract the battery
Remove the plastic case
Carefully peel the plastic cover to expose the cells
Draw a diagram of the wiring and then cut the individual cells appart
Use similar 18650 for rebuilding the pack. Be sure that they are charged at the same level too
You can use a normal soldering iron for attaching the nickel strips but it is recommended to use a spot welder. There is a cheap korean option https://m.blog.naver.com/aulakiria/22099...
Еще один человек закончил это руководство.
