Replacement de la vitre tactile et de l'écran LCD du Samsung Galaxy Note8
Выберете то, что вам нужно
    • Insérer un commentaire.
Финишная черта
21 участников успешно повторили данное руководство.
ian mdx
Участник с: 06/30/16
8 968 Репутация
Автор 17 руководств
9 Комментариев
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Ответить
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Ответить
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Ответить
Will the phone remain waterproof after this repair?
cj-dm - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 13
За последние 30 дней: 32
За всё время: 24,067
