Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will take you step-by-step on how to replace your buttons.
Запчасти
Детали не указаны.
  1. Before disassembling your Atari Lynx, be sure the device is powered off.
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Remove the control panel by pinching the sides with your fingers and lifting  it away from the Atari.
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from front panel of Atari.
    • If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from front panel of Atari.
  6. To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad. The buttons should fall out once the screws have been removed.
    • To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad.
    • The buttons should fall out once the screws have been removed.
Заключение
Tyler Williams
Участник с: 26.01.2014
317 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 1-42, Maness Winter 2014 Участник Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 членов
Автор 13 руководств
Один комментарий
Thanks for the guide. The title photo shows a Lynx II, however, while all the detailed instructions are for the original Lynx (I) which is built differently.
It would be great to have a Lynx II disassembly and MOSFET Q12 replacement guide.
Siegfried Lenz - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 1,627
