Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
Выберете то, что вам нужно
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: шаг 1, изображение 1 из 1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 2, изображение 1 из 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 2, изображение 2 из 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 2, изображение 3 из 3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 3, изображение 1 из 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 3, изображение 2 из 2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 4, изображение 1 из 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 4, изображение 2 из 2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 5, изображение 1 из 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 5, изображение 2 из 2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 6, изображение 1 из 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: шаг 6, изображение 2 из 2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
Финишная черта
Еще один человек закончил это руководство.
Michael Loboda
Участник с: 10/07/19
157 Репутация
1 руководство автора
Команда
Eastern Washington University, Team S2-G8, Munoz Fall 2019 Участник Eastern Washington University, Team S2-G8, Munoz Fall 2019
EWU-MUNOZ-F19S2G8
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 49
За всё время: 3,924
