Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The speaker is an output component that plays sound.
Запчасти
Детали не указаны.
  1. Using a spudger, wedge the tip between the front and back case to pry them apart. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together. Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. The black rubber button pad can be removed by simply picking it up.
    • The black rubber button pad can be removed by simply picking it up.
  3. Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Lift open the LCD screen and button input chip to access the entire midsection plate.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case. Once unscrewed, pick up the case and put it to the side.
    • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
    • Once unscrewed, pick up the case and put it to the side.
  9. With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
    • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
Заключение
Еще один человек закончил это руководство.
Westley Courchene
Участник с: 13.01.2015
3 230 Репутация
Автор 14 руководств
Команда
USF Tampa, Team 1-1, Remmell Fall 2015 Участник USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 185
