Replacing Electrolux PLD2850RDC2 Lower Door Seal
Выберете то, что вам нужно
  1. Replacing Electrolux PLD2850RDC2 Lower Door Seal, Removing the outer door panel screws: шаг 1, изображение 1 из 1
    • Start by opening up the dishwasher door to expose the outer door panel screws.
    • Locate the 4 screws that attach the outer door panel to the door assembly and remove these completely from the door.
    • Next, just slightly loosen the 4 control panel screws at the top of the door panel to make removal of the panel easier.
  2. Replacing Electrolux PLD2850RDC2 Lower Door Seal, Removing the outer door panel: шаг 2, изображение 1 из 1
    • After removing the screws, close the dishwasher door and slide the outer door panel downward by applying a little force to the handle. The door should slide down about an inch.
    • Once the panel sides down, pull the handle outward towards you to remove the outer door panel and expose the inner door panel.
  3. Replacing Electrolux PLD2850RDC2 Lower Door Seal, Removing the old seal: шаг 3, изображение 1 из 2 Replacing Electrolux PLD2850RDC2 Lower Door Seal, Removing the old seal: шаг 3, изображение 2 из 2
    • Now that the outer door panel is removed, you can open the door and locate the lower door seal on the bottom edge of the door.
    • Gently pull the exposed edge of the seal away from bottom edge of the door and towards the dishwasher tub.
  4. Replacing Electrolux PLD2850RDC2 Lower Door Seal, Alignment tab placement: шаг 4, изображение 1 из 1
    • Note that when installing the new seal there is an alignment tab located on the right hand side of the dishwasher (your right while facing the dishwasher). This tab needs to fit into the existing slot. If you have difficulty aligning this tab, you can remove the lower dishwasher rack to get a better view of the bottom side of the door.
Заключение
5 участников успешно повторили данное руководство.
Ross
Участник с: 10/18/14
276 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 30
За последние 30 дней: 115
За всё время: 9,911
