Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through removing and replacing the Nintendo DS battery.
Выберете то, что вам нужно
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise.
Remove the battery door.
Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
Make sure to press the power button on the Nintendo DS when finished to confirm the battery is working.
10 участников успешно повторили данное руководство.
