Инструменты
Запчасти
Никакие детали не требуются.
Press down on the button located at the bottom of the phone, using the center ridge as a guide.
Pull the phone apart from the bottom, keeping the button pressed down.
Place a finger or plastic opening tool in the gap between the battery and the phone.
Gently lift the battery out.
Locate the plastic latches on the left and right sides of the phone.
Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
Turn the faceplate so the number pad faces downward.
Lift the number pad out of the faceplate.
Apply new faceplate.
Follow the instructions in reverse order to reassemble the phone.
