Введение
Use this guide to remove or replace the SIM card in your Samsung Galaxy S4.
Инструменты
Запчасти
Детали не указаны.
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
76 участников успешно повторили данное руководство.
Комментариев: 3
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
Removing sim card tray?
