Введение
If the Sonos Play:1 has a damaged power/volume switchboard, this could prevent the device from powering on or off and could render the volume nonadjustable. To replace the switch board, remove the screws and protective plastic cover fastening the top cover to the speaker housing. Inside the cover lies the power/volume switch board.
Выберете то, что вам нужно
Using a metal spudger, pry open a corner of the adhesive tape.
Use precision tweezers to remove the adhesive tape.
Remove the four 10 mm Torx security #10 screws that hold the base together.
Remove the base by lifting it vertically away from the bulk of the device.
Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
Using precision tweezers, remove the metal bracket.
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, pry open the top cap containing the power and volume button.
Vertically remove the top cap.
Using a plastic opening tool, pry open the circuit flap.
Once flap is loosened, use your hand to remove the circuit wire.
Using a screwdriver with a Torx T6 bit, remove the four highlighted 7mm screws.
Using you fingers remove the protective plastic plate covering the device.
Using your fingers remove the plastic cover plate securing the switchboard.
Using your fingers, remove the power/volume switch board.
4 участников успешно повторили данное руководство.
9 Комментариев
Where can I get the replacement power button?
Same quesion here from DK
where can i find board
