Введение
Your guitar will eventually need its strings replaced, but online guides may not suit your particular guitar. This guide is for those with a floating tremolo bridge. It will walk you through safely and effectively replacing the strings, ensuring they remain in good condition longer.
For Step 8, when cutting off excess string, be cautious with steel strings as the ends are sharp.
Ensure the guitar is not plugged into any power source before you start.
Выберете то, что вам нужно
Use a string winder to loosen each string by turning the peg counter-clockwise.
Once loosened, pull the string out of the tuning peg.
Move to the bridge of the guitar and push the strings through.
Flip the guitar around and pull the string out of the hole in the back.
Insert the new strings through the holes in the back.
Feed the string through to the other end and pull until the end of the string is reached.
Align each string to the groove in the nut.
Insert the strings into the corresponding tuning peg.
To tie the knot, begin by looping the string around and then under.
Pull up on the string until you can feel tension.
Loop the string over and pull.
All that's left to do is tune your guitar and then it will be ready for playing!
