Введение
This guide gives step-by-step instructions for replacing strings in the most appropriate manner, ensuring that you can do some seriously righteous jamming on your New Yorker!
Выберете то, что вам нужно
Place the mandolin on a firm, level surface with adequate lighting.
Loosen the tuning nob.
Carefully remove the top end of string from the tuner in the mandolin head.
Unhook the old string from the tail of the mandolin.
Remove the string from the bottom.
Select a new string, and then insert the bottom end of it through the bridge at the tail.
Pulling the string taut, bring its top end across the nut and into the tuning peg.
Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
Pull the string down, towards the fretboard, and run the string underneath itself.
Pull the string tight so that it wraps around the tuning peg.
Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
3 человек успешно провели ремонт по этому руководству.
