Введение
Whether you're stacking firewood for the winter or heading into town for coffee, don’t let a blown-out button keep you from wearing your favorite pair of pants. With the help of this guide and a hammer you can have your pants or jeans ready for action in minutes.
For replacement parts or further assistance, contact Patagonia Customer Service.
Инструменты
Запчасти
Lay your jeans front-side up on a sturdy table or workbench.
Unzip the fly and open the jeans at the waistband to reveal the hole where the button is missing.
Hold the waistband at the hole and turn it over, so you can see the back of the hole.
Place a flat work surface like a scrap piece of wood or a cutting board directly beneath the tack and between the front and back of the jeans.
Be sure to use a small (one pound) hammer or mallet to prevent breaking the button.
Test out your new button by buttoning the jeans to ensure the new button is set and secure.
36 участников успешно повторили данное руководство.
Комментариев: 8
Nice, but let's consider how this situation occurs. The tack comes out of its hole, just simply replacing it is not realistic, unless the new tack is significantly bigger. So how do you "repair" the hole such that it will hold a tack again?
As noted in step 2, you can move the tack over to where the denim isn't damaged. If that will cause the jeans not to fit properly, you can sew a folded piece of denim behind the hole (sew around the edges on the inside of the jeans) and punch the tack through the new piece.
I didn´t have a new button and was in a pinch. Just ripped the old button off completely, jammed it in the tail end of a hammer and yanked it apart with som pliers. Then i followed the instructions in this fix. Worked like a charm, so far...
The best thing to do is patch the hole. I simply use fabric glue and some pieces of blue jeans that you probably have hanging around. Trim off the extra threads and then apply fabric glue to the back of the waist band covering the hole made by the old button. Do the same on the front and then let dry. about 30 minutes or so, if you have a machine I always stitch back and for on the edges. Trim any edges or use additional glue to tack them down. Now because you have strengthened the hole carefully push the back of the button through where you can see the end, add the front to the nail end and turning the garment face down on a protected hard surface hammer about 3 times and check to see if it is sturdy, continue to hammer until you have reached the objective. Now you have got many more years with that button.
