Replacing a Leg from a Wooden Folding Table with Metal Legs
Выберете то, что вам нужно
  1. Replacing a Leg from a Wooden Folding Table with Metal Legs, Metal table leg: шаг 1, изображение 1 из 1
    • Place the table against a flat and firm surface with the legs facing away from that surface.
  2. Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 2, изображение 1 из 3 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 2, изображение 2 из 3 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 2, изображение 3 из 3
    • Squeeze the two levers for the release mechanism, then remove the bottom section of the metal leg by pushing it out.
  3. Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 3, изображение 1 из 2 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 3, изображение 2 из 2
    • Inspect the table legs for any sustained damage.
    • Pro Tip: The top leg is an example of deterioration of the leg from constant use, and the bottom is an example of a leg in good working condition.
  4. Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 4, изображение 1 из 3 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 4, изображение 2 из 3 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 4, изображение 3 из 3
    • Use a Phillips #2 screwdriver to remove all ten 12mm screws from the table leg.
    • Make sure when removing the final screws that you hold the metal leg piece up, so that after the removal of the final screws, the leg doesn’t fall off the table.
    • Pro Tip: Apply constant pressure to the screwdriver to gently remove the screws and avoid stripping the screw head.
  5. Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 5, изображение 1 из 1
    • Inspect the removed leg for any sustained damage.
    • Pro Tip: Look for loose parts or areas that may have suffered from corrosion.
  6. Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 6, изображение 1 из 2 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 6, изображение 2 из 2
    • Using the same ten 12mm screws, use the Phillips #2 screwdriver to secure the table leg back in its designated position.
    • Pro Tip: Apply pressure to the screw driver to easily attach the screws and avoid stripping the screw head.
  7. Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 7, изображение 1 из 2 Replacing a Leg from a Wooden Folding Table with Metal Legs: шаг 7, изображение 2 из 2
    • After all the screws are secured in their original position, verify that the bottom of the table has been properly installed, and stand it up to ensure stability and safety for future use.
Финишная черта
Tiago Tella
Участник с: 01/30/20
145 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 647
