Введение
This guide will walk through the process of identifying possible sources from instability in a Wooden Folding Table with Metal Legs, and how to replace the damaged leg. The table leg is an essential part as it allows the table to stand up. Some reasons as to why a replacement would be necessary is the leg is wobbly and/or the groves for which the pins enter in order for the table leg to become secured are worn out. Not everyone has the finances to go and buy another table, especially if multiple of the same kind of table is required. Following this guide will permit extension of the table’s service life.
Выберете то, что вам нужно
Place the table against a flat and firm surface with the legs facing away from that surface.
Squeeze the two levers for the release mechanism, then remove the bottom section of the metal leg by pushing it out.
Using the same ten 12mm screws, use the Phillips #2 screwdriver to secure the table leg back in its designated position.
After all the screws are secured in their original position, verify that the bottom of the table has been properly installed, and stand it up to ensure stability and safety for future use.
