Replacing a ZIF Connector Locking Flap
Выберете то, что вам нужно
    1. Replacing a ZIF Connector Locking Flap, Align the Locking Flap in the Correct Position: шаг 1, изображение 1 из 2 Replacing a ZIF Connector Locking Flap, Align the Locking Flap in the Correct Position: шаг 1, изображение 2 из 2
      • A Locking flap with the markings "DDF" and "30d" visible on the top is shown in the first photo. It is positioned in the right direction to be replaced.
      • If the locking flap is positioned the wrong way it is easy to turn it around.
      Спросите у FixBot
      Добавить комментарий
    2. Replacing a ZIF Connector Locking Flap, Insert One Side of the Locking Flap: шаг 2, изображение 1 из 1
      • Lift the back of the locking flap to position it vertical to the ZIF connector.
      • Insert one side of the flap first. A slight resistance will be felt before it is positioned.
      • You have to be very gentle so as not to break it. The use of tweezers and a magnifying glass is recommended.
      • The gold pins of the connectors must fit inside the flap. The "grid" of the flap is therefore positioned between the gold pins and the silver pins.
      Спросите у FixBot
    3. Replacing a ZIF Connector Locking Flap, Progressive Insertion of the Locking Flap: шаг 3, изображение 1 из 1
      • Gradually insert the flap from right to left.
      • Keep the flap in the vertical position so that it does not come out of its housing.
      Спросите у FixBot
    4. Replacing a ZIF Connector Locking Flap, Insert the Left Side: шаг 4, изображение 1 из 1
      • Finish by inserting the left side in the same way as the right side.
      • This is a delicate operation. On occasion the flap comes out of the housing. If that happens, starting over is the best option.
      • Finish by pushing the flap as far as possible inside the connector.
      Спросите у FixBot
    5. Replacing a ZIF Connector Locking Flap, Functional Check: шаг 5, изображение 1 из 2 Replacing a ZIF Connector Locking Flap, Functional Check: шаг 5, изображение 2 из 2
      • Verify that the flap pivots correctly without coming off its axis.
      Спросите у FixBot
Заключение
You can now resume reassembly where you left off.
13 человек успешно провели ремонт по этому руководству.
Особая благодарность этим переводчикам:
fr en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
AlexFixeurs
Участник с: 06/20/15
1 674 Репутация
Автор 4 руководств
Команда
Fixeurs Участник Fixeurs
Business
1 член
Автор 39 руководств
7 Комментарии к руководству
Bonjour
Vous pouvez me confirmer que le connecteur ne fonctionne pas sans le clapet ? Je l'ai cassé et le clavier ne marche plus.. J'ai commandé 5 connecteurs pour essayer de remettre le clapet.. Merci
Hichem Ben - Ответить Поделиться
Bonjour. Un connecteur bien enfoncé, avec un bout de scotch pour le maintenir en place pourrait fonctionner, mais il pourrait aussi ne pas fonctionner ou tomber en panne par intermittence. Vous pouvez faire le test, dans l'attente de l'arrivée de vos connecteurs neufs, en sachant que si ça ne maarche plus, cela vient surement de là !
AlexFixeurs - Ответить Поделиться
Merci pour votre réponse.
Après avoir cassé le clapet, j'ai essayé d'insérer la nappe et d'allumer, ça ne marche pas car le bouton d'allumage fait partie du clavier.. J'ai maintenu une pression avec mon doigt ça marche pour quelques boutons.. J'attends la pièce pour récupérer uniquement le clapet, j'espère que c à cause de ça (logiquement si) malgré que je n'ai pas compris son réel rôle ce clapet.. Car la nappe me semble touchée les dents du connecteur !
Pour le détail bien enfoncé je n'arrive pas à le faire il persiste 1mm de la partie blanche de la nappe à l'extérieur comme sur votre photo.. Donc le scotch si il servira qu'à maintenir la nappe en place ça ne va pas régler le problème.. Io faut maintenir la pression par le clapet
J'ai réussi à le mettre mais beaucoup de boutons ne fonctionne pas.. Je pense que j'ai abîmé la nappe à force de la manipulé..
Статистика просмотров:
За последние 24 часов: 16
За последние 7 дней: 124
За последние 30 дней: 545
За всё время: 14,480
