Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Make it easier to zip up your favorite jacket by replacing a missing zipper pull tab. It only takes a few minutes and afterward you’ll be able to grib your zipper pull with mittens or gloves.
For replacement parts or further assistance, contact Patagonia Customer Service.
Video Overview
Zipper pull replacement overview.
  1. Get your new zipper pull and position it with the pull-tab down. Lift up the zipper, as if you were pulling the zipper closed.
    • Get your new zipper pull and position it with the pull-tab down.
    • Lift up the zipper, as if you were pulling the zipper closed.
  2. Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally. Pull the zipper pull through the smaller hole. Pull the zipper pull through the smaller hole.
    • Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally.
    • Pull the zipper pull through the smaller hole.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Rest the zipper back in its normal, hanging position. Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
    • Rest the zipper back in its normal, hanging position.
    • Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
  5. Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper. Bring the zipper pull-tab through the loop.
    • Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper.
    • Bring the zipper pull-tab through the loop.
  6. Pull the zipper pull-tab snug. The zipper pull should now be inserted and lay flat.
    • Pull the zipper pull-tab snug.
    • The zipper pull should now be inserted and lay flat.
Финишная черта
3 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 05.03.2012
83 069 Репутация
Автор 132 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 58
За последние 30 дней: 245
За всё время: 14,763
