Введение
This repair guide will give you step by step instructions on how to remove the Macintosh PowerBook 1400c Monitor.
Выберете то, что вам нужно
Turn the device upside down and then locate the battery latch near the front of the device.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
Once the end cap has been loosened by the spudger, pull outwards on the end caps.
Identify the 4 total screw under the end caps (2 under each end cap).
The two outside 16mm long screws
The two inside 5.4mm long screws
Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
Identify where the left and right monitor cords are attached to the logic board
The base of the left monitor cord
The base of the right monitor cord
To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
5 участников успешно повторили данное руководство.
