Введение
A common type of ironing board has a lever fixed by a metal plate that is supposed to allow the legs to open and close. However, the metal plate can be damaged. When that happens, the ironing board will not be able to open and stand up. Need to iron clothes but ironing board doesn't stay up? Check out our repair guide to learn how to replace the broken metal plate of the ironing board!
Выберете то, что вам нужно
Place the ironing board face down on a flat, stable surface.
Using a 1/8" drill bit, drill four holes on each corner where the screws will be placed.
Using a screwdriver, screw on the new plate with the #10-32 x 3/8" pan-headed screws.
5 участников успешно повторили данное руководство.
