Введение
This guide will explain how to replace the air intake filter in the ResMed AirSense 10 ventilator. Regularly check the intake air filter to prevent the entry of dust and water. Replace the intake air filter every 6 months or if there are any damages or blockages to the filter.
Выберете то, что вам нужно
Pry open the intake air filter cover on the bottom of the left side panel of the device.
Remove the used air filter and inspect for damages or blockages.
Replace the air filter as needed.
2 участников успешно повторили данное руководство.
2 Комментариев
The filter has a smooth side and a fuzzy side. Which side goes against the cover? Or doesn't it matter? Thanks.
