Выберете то, что вам нужно
Push upwards at the bottom of the control module to separate it from the two locking pegs on the base plate.
Pull the control module down to disconnect and remove it from the base plate.
Place the control module so the labels are facing upright.
Use a TR9 Torx screwdriver to remove the top screw.
Remove the filter housing from the control module.
Use a TR15 Torx screwdriver to remove the three screws from the bottom of the control module.
Place the control module face up.
Open the face plate to the right.
Disconnect the 5 connectors along the left side of the control circuit board.
Use the plastic opening tool as a lever to release the plastic motor frame from the retaining tab at the bottom of the module.
With the tab released, pivot the plastic frame up and away from the control module.
4 участников успешно повторили данное руководство.
