Retina MacBook 2017 Left Speaker Replacement
Выберете то, что вам нужно
  1. Retina MacBook 2017 Left Speaker Replacement, Disable Auto Boot: шаг 1, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement, Disable Auto Boot: шаг 1, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement, Disable Auto Boot: шаг 1, изображение 3 из 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - Ответить
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - Ответить
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - Ответить
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - Ответить
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - Ответить
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - Ответить
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - Ответить
    Not able to do that with damaged screen
    richardjgreen - Ответить
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - Ответить
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - Ответить
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - Ответить
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - Ответить
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - Ответить
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - Ответить
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - Ответить
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - Ответить
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - Ответить
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - Ответить
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - Ответить
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - Ответить
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - Ответить
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - Ответить
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - Ответить
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - Ответить
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - Ответить
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
  2. Retina MacBook 2017 Left Speaker Replacement, Unfasten the lower case: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    IMPORTANT. You’re not removing the bottom, yet. This step is solely to separate the panel from its clips, permitting inside access.
    Chris Leeds - Ответить
    The screws go in tangent to the curve of the case. If you aren’t used to handling small hardware try turning the screw counterclockwise while you feel for the hole until you feel it drop, that means the threads have aligned. It takes only light finger torque when they are threaded correctly
    abscate - Ответить
  3. Retina MacBook 2017 Left Speaker Replacement: шаг 3, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 3, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 3, изображение 3 из 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  4. Retina MacBook 2017 Left Speaker Replacement: шаг 4, изображение 1 из 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  5. Retina MacBook 2017 Left Speaker Replacement: шаг 5, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 5, изображение 2 из 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    This displays two black pics to prop up the MacBook, but the kit only includes one black pic.
    Kyle Swafford - Ответить
  6. Retina MacBook 2017 Left Speaker Replacement: шаг 6, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 6, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 6, изображение 3 из 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    cannot turn on the led after replacing the new screen, even after following the turn on instructions upper…
    Laurent Pierre - Ответить
    on reassembly, I had to plug my laptop in to reactivate the LED light
    aaron_vandyke2003 - Ответить
    Does anyone know how to turn it back on..? I plugged the laptop in and saw the LED Light, but it won’t turn on
    mmcsorley - Ответить
    After reassembly I could not restart my MacBook using the power button or after SMC reset (shift-ctrl-option-pwr). I had to connect my MacBook to its charging cable to get the battery LED to re-illuminate. After that it was all normal.
    Richard Lovatt - Ответить
    It took a few minutes on the power adapter for my computer to turn on after it was reassembled.
    Luk Chl - Ответить
    mine doesnt turn on w anything, i forgot to click the buton to disconnect :_/
    cristian.campuzano - Ответить
    Same issue as above peeps. Followed ifixit directions verbatim and wasn't getting anything after screwing everything back in. Plugged in original 45W power block and waited, after few minutes battery LED came on and a min. or two after that, was able to get screen to turn on. Hope this helps somebody else.
    Brandon Elliott - Ответить
    May I ask how to get screen to turn on. I cannot get it work..
    Xiubo Zhang - Ответить
    For those whose Mac won't turn on.
    See step 16
    To reconnect this cable, first line up the metal bracket over the screw holes, then "PRESS DOWN" on the middle of the bracket.
    There is a connector under the bracket, which you can't see if you don't see under.
    Not having it in mind, you will not PRESS DOWN the middle of the bracket and there is no connect.
    hls2005 -
    Thank you @Xiubo Zhang - This solved my problem! Please everyone check this connector if you have trouble turning your Macbook on after replacing the battery.
    Miksu -
    There needs to be mention of procedure for getting the repaired MacBook to power up again after the repair is completed.
    I also am running into the issue described by others. MB will not come on again, even after being plugged into power and performing an SMC reset.
    Kinda stuck….
    Carlos Perez - Ответить
    Hi, I tried everything and my MacBook will not start up after replacing the bottom case with a battery installed. I decided to put back on the old case with the battery that needs servicing and it still will not power on. I am fairly experienced taking apart laptops I was an Apple service tech for 15 years. this has me baffalled. Any hints BTY the logic board does not show any power coming from the AC charger the power LED is not lit up
    eestern - Ответить
    I had trouble with this as well. What worked for me is to plug in power using the stock 29W USB C power brick that originally came with this Macbook. Trying other, lower powered, power adapters did not work. Use this advice with caution as there are multiple (i.e substantiated) comments that indicate that first power up should only be with a 5W adapter! So perhaps try this strict sequence: try with a 5W adapter, then and only then try with the 29W adapter. Or even slightly better, if everything else has completely failed, only then try full power 29W adapter.
    LexxOne - Ответить
    How long did you wait to get it power back on? I replaced my logic board and tried to connect the power charger but it doesnt still turn on.
    Herb -
    The easiest error to make when working on this motherboard if applying full voltage after re-assembly. According to the big A, the motherboard on these Macbooks need to be “woken up” with a 5 watt (phone size) charger. Applying the normal 29 watts may render your system unusable.
    Noah - Feb 18, 2021
    Hello Noah,
    It seems your remark is only valid for the 2015 and not the 2016 edition.
    David - Mar 3, 2021
    While it’s true that the internal documentation specifies this for a 2015, after frying 2 motherboards with a normal charger, I spoke with the engineers and they told me that this also applies to 2016 and 2017 macbook main logic boards. I say- It can’t hurt to try to wake them up with a 5 watt charger first! Please take 5 minutes to save your motherboard.
    Noah - Mar 4, 2021
    Noah - Ответить
    I plugged in my charger and the LED came on. The computer gets warm but the screen is not turning on. The keyboards doesn’t seem to respond to recovery options. Any suggestions?
    J'Trel Sapp -
    Hello in muy case the power LED does not go dark (off) . Holding more than 10 sec and nothing. Somebody?
    Flavio - Ответить
    The led light doesn’t turn off on mine either. Held for 10 sec 3 times and still on. How do I turn it off now? And will it damage the computer if I work on it with the light on?
    sfalba - Ответить
    Also, which way should the track pad flex cable face when reinstalling it?
    sfalba - Ответить
    When I try to restart, I see the battery symbol flash on the screen. It shows 100% (hooray?) but then never boots up.
    paul0 - Ответить
    I had basically this when doing a screen replacement (and the ZIF connector ribbon which basically crumbled to dust as I touched it). Including no sound, no light, no boot, no logos, I had a USB connected sound once when plugging it into my windows PC which i guess confirmed it wasnt totally fried, but I had left it plugged in to a few different chargers (not the 20w or whatever one since I read it could damage it if it was not powering normally. could be total BS) and had it sit from 15-30 minutes on each. all nearly no sign of life, though one re-disassembly showed the previously unlit power LED was on again. I went to let it sit on the officical charger overnight thinking it was dead, but it just randomly booted and is working fine now. TLDR be patient with apples BS.
    MrRooter forthewin - Ответить
  7. Retina MacBook 2017 Left Speaker Replacement: шаг 7, изображение 1 из 1
    • Close the MacBook and carefully flip it upside-down.
  8. Retina MacBook 2017 Left Speaker Replacement: шаг 8, изображение 1 из 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  9. Retina MacBook 2017 Left Speaker Replacement: шаг 9, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 9, изображение 2 из 2
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Where can I find a replacement cable?
    John Comix - Ответить
    Just worked on one that was missing the tape from the factory, so yours may not have it either.
    maccentric - Ответить
    that cable got damaged, and now my macbook won't turn on anymore. Does this cable prevent the macbook from working?
    ITZ CRONOMO - Ответить
    I have the same issue. Th trackpad cable snapped while I was replacing the LCD screen. I have ordered a new cable from Amazon but I am not sure if that would cause the laptop to not power up (it's not power related)
    Raj Venkat -
  10. Retina MacBook 2017 Left Speaker Replacement: шаг 10, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 10, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 10, изображение 3 из 3
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    The small retainer flips up about 90 degrees from locked position
    abscate - Ответить
    The keyboard and trackpad don't work after the repair, what can I do? They don't even show up in System Report.
    bredelet - Ответить
    I found that the connector was not pushed enough in. Works now.
    bredelet -
    I flipped up the small retainer -- but when I tried to flip it down, it flew off. The tabs that mount the retainer are very small, and I couldn't get it back on. Left it out, taped down the cable.... and so far the computer, battery, and trackpad are working.
    Bessel Sphere - Ответить
  11. Retina MacBook 2017 Left Speaker Replacement: шаг 11, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 11, изображение 2 из 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  12. Retina MacBook 2017 Left Speaker Replacement: шаг 12, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 12, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 12, изображение 3 из 3
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  13. Retina MacBook 2017 Left Speaker Replacement: шаг 13, изображение 1 из 1
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    From my experience it’s important to carefully press and hold the small button above left of the Battery Discharge label. Use a plastic spudger or finger tip. The illuminated yellow LED to the right will go off. I believe this discharges remaining electricity from logic board protecting it during repair.
    * I cannot find any documentation to support this, but I have damaged boards by not including this step.
    I don't know what guide your on, but step 6 of the guide to replacing the USB-C cable has you press this button (3 times even).
    maccentric -
    What is with the all plastic end of this cable that appears to just be glued right on top of its connector?
    Does the new one just stick back right on top?
    (In this photo it is the bottom side of the cable below the white water indicator sticker)
    Elizabeth Erkelens - Ответить
  14. Retina MacBook 2017 Left Speaker Replacement: шаг 14, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 14, изображение 2 из 2
    Battery Blocker
    $3.99
    Купить
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    What happen if you don’t disconnect the battery? I didn’t and I saw smoke coming out when I connected the pad flex cable and the computer still started up
    DSANTIAGOSOY - Ответить
    If you don’t disconnect the battery you might accidentally short something on the logic board since power is still running through everything while you’re working on it. You can complete the repair without disconnecting the battery, but you risk accidentally breaking your logic board. It’s much safer to keep the battery disconnected while you’re working.
    Adam O'Camb -
  15. Retina MacBook 2017 Left Speaker Replacement, USB-C and Audio Jack Disconnect: шаг 15, изображение 1 из 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Phillips #00 screw
    • Some variations of this model may use a Tri-point Y00 screw.
    • 3.5 mm T5 Torx screw
    I’m at this point and the 1.1 mm Phillips #00 screw won’t budge and now I fear it could be stripped? Now what???
    Y'vonne Feeney - Ответить
    You could try to cover the tip of your screwdriver with a thin rubber glove to improve the grip on the screw while applying a little more downward force for the initial jolt. That might loosen the screw.
    Tobias Isakeit -
    The USB-C ribbon cable breaks very easily when being attached. Any particular tricks for ensuring that it won’t snap somewhere while being installed?
    bfg737 - Ответить
    With my iFixit screwdriver kit, these were Philips #000, not #00.
    Paul Nishikawa - Ответить
    This was #000 for me as well
    Adam Hupp - Ответить
    I was at the 1.1 mm and couldn't get it open with the 00. I ordered the 000 but it still won't budge. I tried the glove idea and as much pressure as I'm comfortable giving. I'm pretty sure the screw is stripped. Any ideas or advice or am I in trouble?
    johnny gutierrez - Ответить
    Got stuck here too. Bought a Chinese laptop/phone servicing kit and guess what? No 1.1mm philips. The 1.2mm it does include doesn’t sit tightly enough. Had to order separately….
    David Miller - Ответить
  16. Retina MacBook 2017 Left Speaker Replacement: шаг 16, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 16, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    At re-assembling, when you reconnect this cable, pressing centre of metal plat is extremely important. You should feel tiny click when it connected properly. I encountered unrecognised external HDD and external monitor through USB-C even though charging in/out was OK, i.e failure of data transmission. I needed to re-open the back cover and pressed the metal plate again, then USB-C connection worked properly.
    Aki Mochi - Ответить
    After this step, I flipped the Macbook over once more and opened it up 90 degrees, supported on the back. Proceeded directly to step 25. Seems safer, those fragile connectors and flimsy cables give me heebie jeebies.
    I endorse maccentric's comment above. I think it's better to remove the battery (carefully) with the logic board in place. I did that and the computer works fine after reassembly.
    In fact, I removed a couple more cables than this step, but got creeped out by the many delicate cables being moved, and user comments about failed disconnect and reconnect, so I skipped to step 25 lower down.
  17. Retina MacBook 2017 Left Speaker Replacement: шаг 17, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 17, изображение 2 из 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  18. Retina MacBook 2017 Left Speaker Replacement: шаг 18, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 18, изображение 2 из 2
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
    • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
    Make sure at reassembly that you insert the ribbon cable in to the jack board fully. It seems to take an extra push. The white line should disappear when it is seated properly. I didn’t get it in all the way by a fraction of a mm and had no sound (internal speakers weren’t even recognized). Went back and seated the cable fully and sound was back.
    Timothy Dinkelman - Ответить
    I had that same problem, too.
    lyonmissions - Ответить
    Had the same problem, (no audio after reassembly) it did have the startup chime though.
    after re-seating the ribbon cable, it worked for a few days, but then nothing after waking up.
    not even the startup chime.
    Any body got pointers on how to check if i broke the cable or the board? (looks fine...)
    Christian Stanner - Ответить
  19. Retina MacBook 2017 Left Speaker Replacement, Lower Case Assembly Removal: шаг 19, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement, Lower Case Assembly Removal: шаг 19, изображение 2 из 2
    • Use tweezers to peel back the tape covering the display cable connector.
    I won’t have my daughter’s MacBook with its banana encrusted USB-C port until she returns home during spring break — just doing some homework before then. But if the case can lie flat after the audio board ZIF cable is detached, why do you need to detach the display cable connector (Steps 19-24)? It seems that you could jump straight to Step 25 to replace the USB-C port and avoid those steps.
    John Conklin - Ответить
    Hi John, disconnecting the display cable is not necessary, but is recommended to avoid accidental damage to the cable during the rest of the procedure. If you feel confident in the safety of the cable then you can skip ahead. Good luck with the repair!
    Adam O'Camb -
    I skipped ahead to step 25 successfully by making a secure stand for the display and being careful to not strain cables. If you are decently motor skilled this saves you 15 minutes or so. Not recommended if you live with cats who love little screws to chase
    abscate - Ответить
  20. Retina MacBook 2017 Left Speaker Replacement: шаг 20, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 20, изображение 2 из 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  21. Retina MacBook 2017 Left Speaker Replacement: шаг 21, изображение 1 из 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    I found it helpful to stick one of the triangular picks in between the table and the retaining flap to keep them separated.
    Kofi Kantanka - Ответить
  22. Retina MacBook 2017 Left Speaker Replacement: шаг 22, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 22, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 22, изображение 3 из 3
    iOpener
    $12.99
    Купить
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
    Great, another new fragile display cable to deal with. Thanks Apple.
  23. Retina MacBook 2017 Left Speaker Replacement: шаг 23, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 23, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 23, изображение 3 из 3
    • Hold the retaining flap open.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap. Keep it closed throughout your repair.
    • During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
    I’m pretty sure I understand the instructions here, but I had to think about it a little longer because “… must remain closed when the cable is reinserted during reassembly …” was not clear to me right away. The retaining flap I discovered, is super delicate, and hence my paranoia, so I wanted to point this out in case anyone else felt like me: ''''Is it correct to assume that your instructions could be interpreted as:
    “After disconnecting the cable, close the retaining flap for now to avoid damaging it. When reinstalling the cable, flip up the retaining flap once again, realign and slide the cable with gold contacts facing down.”
    I bent the USB-C corner of the lower case from a short drop onto laminate flooring, so in I went to shape it so the edge wouldn’t snag or scratch things. I am typing on my MacBook that received the body work.
    Thank you for your guidance!
    John Torquido - Ответить
    For @seriouslyjohn and anyone else who might be wondering: “the flap must remain closed when the cable is reinserted” means keep it closed. Do not reopen the flap to insert the cable; just insert it carefully while leaving the flap closed. I know it probably runs counter to the procedure you’re used to, but Apple’s documentation is very clear on this, and I have to think it’s for a reason. My advice is to follow the instructions as written and don’t try to reinterpret them ;) Congrats on a successful repair!
    Jeff Suovanen -
    Oops! I most definitely did NOT reinsert the cable into a closed connector. We can only wonder why Apple instructed this step to be counter-intuitive. I’ll pay closer attention to any weirdness that may arise, but the MacBook has been traveling and performing as it should; I’m going to avoid reopening the case, as easy as it is, until I have a good reason to do so. Thank you for replying and updating the guide!
    I would argue that you should NOT close the retaining flap. I followed the directions to the letter, and when I started up the MacBook, the display did not register since the I wasn’t able to reseed the cable fully without worrying about tearing the cable. I did hear the computer charging and saw that the keyboard lit up, so I knew the MacBook was working besides the display. I looked up another video on Youtube that left the retaining flap open when reinstalling, so I took apart the Macbook again and tried it that way, and IT WORKED! The cable wasn’t fully reseated with the retainer open and I’m not sure if that was my fault or not, but with the retainer flap open, it was easier to see that. My 2 cents. Good luck everyone!
    Sulmo Kim - Ответить
    I initially tried inserting the cable with the retaining flap closed (as described), however after completing reassembly the MacBook could be heard to start but without any display action (no backlight, no graphics - also tried resetting the SMC). Being suspicious of this step based on the comments above, I tried re-inserting the cable with the retaining flap open before subsequently closing the flap. It may have just been my perception but insertion with the retaining flap open certainly appeared to result in a more robust mating of cable and connector. After reassembly and reset of the SMC I at least saw backlight action although no graphics still. A subsequent boot into to diagnostics mode resulted in the graphics coming to life.
    Maybe my re-insertion while the retaining flap was closed was not quite correct (although I was certainly trying to be careful), but my experience was that success was achieved making the cable insertion while the retaining flap was open.
    Paul Richards - Ответить
    It is kind of nice that I don't have to worry about that. The screen cable is literally plug & play. Super easy.
  24. Retina MacBook 2017 Left Speaker Replacement: шаг 24, изображение 1 из 1
    • Separate the upper case assembly from the lower case assembly.
  25. Retina MacBook 2017 Left Speaker Replacement, Logic Board: шаг 25, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement, Logic Board: шаг 25, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement, Logic Board: шаг 25, изображение 3 из 3
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
    Removing the logicboard must be safer way, but battery replacement can be accomplished if you skip here to step 32, and omit 36.
    I'm not sure removing the logic board is safer, you have many more opportunities to break something. I left it connected but removed the screws so I could maneuver the battery underneath. Faster and safer imo.
    maccentric -
    I would strongly advise anyone tempted to follow this advice and skip to 36 to NOT DO THAT. The hardest part of this whole project is removing the old batteries and adhesive. You’re going to want to use the adhesive remover liberally. Getting that on your board, or accidentally gashing at it when you’re trying to wedge out the old battery, is going to ruin it. Trust me, you would hate to go through all this just to find out you fried your board because of this (admittedly tempting) comment. There are seemingly a lot of steps from here to 36, but they’re all pretty easy and fast. KEEP GOING! KEEP FOLLOWING THE INSTRUCTIONS. YOU WILL MAKE IT!
    RDG -
  26. Retina MacBook 2017 Left Speaker Replacement: шаг 26, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 26, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 26, изображение 3 из 3
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  27. Retina MacBook 2017 Left Speaker Replacement: шаг 27, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 27, изображение 2 из 2
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  28. Retina MacBook 2017 Left Speaker Replacement: шаг 28, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 28, изображение 2 из 2
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  29. Retina MacBook 2017 Left Speaker Replacement: шаг 29, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 29, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 29, изображение 3 из 3
    • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
    The supplied tweezer is no good. You need one with grooves as shown in the picture. When re-inserting the antenna connectors, make sure that they are seated properly before pushing down. If you have magnifying equipment, use that to get visual confirmation. I used tactile feedback from my fingers to discern proper alignment. Try not to force it.
    Ki Park - Ответить
    I used the tweezers provided by iFixit. I struggled with both connectors and finally managed to disconnect both, but when I came back to reconnect them, I realized that both connectors on the logic board were loose. Long story short, it turns out that my little exciting adventure changing the battery cost me $530 to send it for repair at Apple Care. I am quite good at troubleshooting Mac and used to work for Apple for many years. This one step is more dangerous than it seems, because you can end up like me, without wifi on your mac. Honestly, for those who think they can do it, think twice. You can thank me later…
    Arthur Liegeois - Ответить
    For me this step was the only point where I had a bit of trouble. The supplied tweezers were not the best for disconnecting the antenna connectors as Ki Park points out already. In my case the outer ring of one of the connectors on the logic board bended slightly. It bended back in place during assembly and the wifi works as normal again after the repair. It is very tricky though, really be careful in this step and use other tools as necessary.
    Arie Machgeels van Ziel - Ответить
    BY FAR THE MOST DANGEROUS PART OF THE JOB!. I broked one connector and spent an hour with high powered magnifiers to try a repair. Wasted an hour on this. Id suggest leaving the logic board in place if possible
    Crisis Guy - Ответить
    I had no problem with this. The key is to come toward the connectors from the opposite direction from that shown in the photo. Easier to grip the connector.
    david - Ответить
    I broke one. Looking back, it may have been safer to detach the motherboard from the case before disconnecting the antenna, as it allows more angles to access them. 😢
    bredelet - Ответить
    I actually put one of the tweezer tines under the connector and used it as a lever gently to pop the antenna connector off the housing. Worked well, but I had to be super careful not to break anything.
    Woodward Price - Ответить
    These connectors are incredibly finicky to reinstall. Precise alignment is critical. You can sort of get a sense of when the connectors are properly aligned by trying to slide them side to side with your finger, but mostly it's a case of trial and error. Don't apply excessive force because you risk damaging the edges of the connectors. When properly aligned they don't exactly click, but you do feel them go in.
    nigel - Ответить
    DO NOT REMOVE THESE. As others have stated these are fragile and finicky to remove and reinstall. Instead, leave them intact and lift up the logic board at a 70 to 80% angle. Use a piece of tape secured to the bottom edge of the computer and the top edge of the logic board to hold it up and out of the way. If you are diligent, you can remove the batteries without touching or messing with the logic board. Use caution, don't get too overzealous, take your time.
    Steven Gibson - Ответить
    tough one - you guys scared me... SOLUTION: HOLD A SECOND TWEEZERS WITH STRAIGHTEDGE ON THE INSIDE EDGE WHILE GENTLY USING PROVIDED POINTY TWEEZER ON THE OPPOSITE SIDE TO PRY UP THE CONNECTOR. FLAT TWEEZER PROVIDES JUST A HINT OF BACK PRESSURE, KEEPS THINGS STRAIGHT WHILE YOU INSERT THE POINTED TIP AND PRY UP GENTLY. INSERT AND LEVER IT UP - I.E. AFTER INSERTION, TWIST THE POINTED END SO PRESSURE IS STRAIGHT UP, FROM UNDER THE MIDDLE OF THE CONNECTOR - DON'T INSERT AND PUSH AWAY FROM YOU. MINE POPPED RIGHT UP THIS WAY (after exploring all other options). IMPORTANT - THE POINTED TIP (PRY SIDE) COMES FROM OUTSIDE OF CASE , OPPOSITE SHOWN IN PICTURE (AS MENTIONED BY PRIOR COMMENTER.). I ACTUALLY NEED RELATIVELY LITTLE PRESSURE USING THIS METHOD TO GET THE CONNECTORS TO POP. INSERT POINTY TIP UNDER THE NARROW SPOT JUST AHEAD OF THE WIRE, BUT BEFORE THE SOCKET
    David Nagle - Ответить
    For reassembly I found it helped to temporarily put the torx screw from Step 14 in so that the logic board is fixed firm and you are not aiming for a moving target with the tiny connectors.
    Tim - Ответить
  30. Retina MacBook 2017 Left Speaker Replacement: шаг 30, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 30, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 30, изображение 3 из 3
    • Pry up the second antenna connector to disconnect it.
    Broke a connector. Now what?
    chrisadams - Ответить
    BEWARE - there are no instructions on how to reassemble this. It goes to step 52 - battery installed and that is it. Easy to pull out, almost impossible to put back in afterwards. So STUDY this to get an idea of how to reattach.
  31. Retina MacBook 2017 Left Speaker Replacement: шаг 31, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 31, изображение 2 из 2
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
    Reassembling NOTE. The left speaker cable needs to be below the logic board when screwing in the right screw. Otherwise you will have to backtrack.
  32. Retina MacBook 2017 Left Speaker Replacement: шаг 32, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 32, изображение 2 из 2
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  33. Retina MacBook 2017 Left Speaker Replacement: шаг 33, изображение 1 из 2 Retina MacBook 2017 Left Speaker Replacement: шаг 33, изображение 2 из 2
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
    • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
    Once the logic board has been replaced, when following these instructions in the reverse order it should be pointed out that the all the flaps are flipped down. A distracted person might try to force in the flat connector before realising that he has to flip up the flap of the new logic board.
    Davide Dante - Ответить
    Ok, went decent but on reconnecting the trackpad cable which I had to replace, it isn't clear which side goes up and which side goes down. From the photos, it appears the copper coated side is down at least on the logic board. Is this the same on the trackpad connector?
    I can't quite find a clear photo of the copper surface position on either end of the ZIF trackpad insertion.
    HELP!
    Marc - Ответить
  34. Retina MacBook 2017 Left Speaker Replacement: шаг 34, изображение 1 из 1
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  35. Retina MacBook 2017 Left Speaker Replacement: шаг 35, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 35, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 35, изображение 3 из 3
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
    • Reattach the tape securely during reassembly.
    “Reattach the tape securely during reassembly.”
    In my case the tape did not stick properly to the lower case anymore and also came a bit loose from the logic board. Nonetheless my macbook works fine after the repair, so I'm not sure how important the EMI tape is. If I experience problems in the future I might open the macbook up again and check the tape and perhaps reattach it better with some new glue. There is probably special glue needed, so I'll look into that when it becomes an issue.
  36. Retina MacBook 2017 Left Speaker Replacement: шаг 36, изображение 1 из 1
    • Remove the logic board.
    If you are replacing the logic board once the machine has been rebuild the 2015 model has to have a 5W power adapter plugged into the machine first before the full 29W power supply otherwise there is a risk of damaging the logic board. Once the power is supplied the battery disconnect LED will switch on and once this has occurred you can remove the 5W and supply the machine with the full 29W power adapter.
    Aaron Dalziel - Ответить
    Noah -
  37. Retina MacBook 2017 Left Speaker Replacement, Left Speaker: шаг 37, изображение 1 из 1
    • Using tweezers, remove the foam pad covering the screw on the right side of the left speaker.
    • If you pull on the foam portion, it will tear. Try to get your tweezers under the adhesive pad holding the foam to the top of the screw.
  38. Retina MacBook 2017 Left Speaker Replacement: шаг 38, изображение 1 из 1
    • Remove the two 4.1 mm T3 Torx screws securing the left speaker to the lower case.
  39. Retina MacBook 2017 Left Speaker Replacement: шаг 39, изображение 1 из 1
    • Prepare an iOpener and heat the lower case directly beneath the left speaker, in order to soften up the adhesive securing the speaker.
  40. Retina MacBook 2017 Left Speaker Replacement: шаг 40, изображение 1 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 40, изображение 2 из 3 Retina MacBook 2017 Left Speaker Replacement: шаг 40, изображение 3 из 3
    • Use a plastic opening tool to pry under the top edge of the left speaker, and separate it from the lower case.
  41. Retina MacBook 2017 Left Speaker Replacement: шаг 41, изображение 1 из 1
    • Remove the left speaker assembly.
Заключение
2 участников успешно повторили данное руководство.
Tobias Isakeit
Участник с: 03/31/14
117 217 Репутация
Автор 188 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 519 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 30
За всё время: 2,973
