Введение
If your controller(s) have button malfunctions, they can be replaced.
Выберете то, что вам нужно
With the controller on its face, remove the five 6 mm Phillips #1 screws.
After screw removal, carefully lift the controller casing.
Pinch the top and bottom of the shoulder pads, then lift out.
There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
To replace the action button pad, lift this part out.
Lift the Select and Start button pad.
If replacing the D-Pad, lift this pad.
Pinch and lift the shoulder button pads.
Support the controller face and push buttons toward the inner case.
Support the controller face and push the D-Pad toward the inner case.
